Can you show the original of this?
Post by Steve Jelf » Tue Dec 17, 2019 3:20 pm
Cleaning up in the shop I came across one of those spurious parts Henry warned us about.
I didn't cut the bag open and take out this top clamp screw but I think you can see it pretty well. I wonder if anybody can post a picture of an original to show how close this reproduction comes. I'm guessing not very.
RustyFords
First Name: Don
Last Name: Allen
Re: Can you show the original of this?
Post by RustyFords » Tue Dec 17, 2019 4:18 pm
Pretty sure this one is.
If it is....then the answer to your question is....not even close.
1924 Touring
Post by DanTreace » Tue Dec 17, 2019 4:48 pm
Two versions, the '23-'25 are stamped flat looking. The '26-'27 pronounced hump at the junction.
Photo posted on the forum, later version on the left.
'23-'25
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Dec 17, 2019 5:00 pm
Thanks Don and Dan, I was wondering myself!
Hank
Post by Steve Jelf » Tue Dec 17, 2019 5:03 pm
So the repop is a not-very-good copy of the 23-25 version. That will be something to watch for at swap meets and auctions.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Tue Dec 17, 2019 5:13 pm
Interesting.
I've got one of each on my soon-to-be-installed top bows.
1924 Touring
Post by John kuehn » Tue Dec 17, 2019 5:16 pm
I guess in desperation you could use a file to smooth out the weld on the repop and make it look decent if that’s all you had and not an original.
Those nuts have been looked over in junk boxes at swap meets like a lot of the small T pieces. Probably more than a few have been thrown out in old parts boxes at old farm auctions also.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Tue Dec 17, 2019 5:20 pm
I’ve had great success with William Bender when it comes to finding OEM versions of little bits like this. It’s been a big help as I’ve obsessively tried to avoid new/repro/shiny bits on my 24 Touring.
I've bought small piles of genuine Ford fasteners (including a steering wheel nut, windshield wing nuts and more) from him at Chickasha for the last couple years and have done business with him through the mail a couple other times.
1924 Touring
Last Name: Strange
Post by CudaMan » Tue Dec 17, 2019 5:27 pm
I made my repro ones look pretty close to the '23 - '25 OEM ones with a little work with a grinder, stripping the plating, and laying on some paint. :)
Post by Original Smith » Wed Dec 18, 2019 10:27 am
I disagree with Dan's conclusion. I believe the above part with the hump is earlier. Why? Because Ford was always looking for ways to cut costs. I have a pair of NOS top to windshield clamps, and they have the flat wing. Doesn't the '26-7 open cars use the same one as the 23-5?
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Wed Dec 18, 2019 11:17 am
This sort of part likely came from a 3rd party manufacturer and therefore wasn’t made in the actual Ford factory, so there were probably several minor variations. These types of items were widely used “general hardware” items and were likely sourced from whoever had the best price and was reasonably close to the Ford print. Doing some rough math, the number of these needed to outfit every roadster and touring car during Fords busiest production month would fit into a 2’x2’x2’ container.
Post by DanTreace » Wed Dec 18, 2019 12:20 pm
About the only way to tell design is to get print of the part or the assembly from the Benson Ford Library.
The top clamping assembly is Fac. No. 3588X, and according to B. Macalley CD parts listing the Top Clamping Wing Screw is Fac. No. 3540 (with date noted as 8/12/22) in the alphabetical with under the line for the Top Bracket Clamping Assembly . However in the numerical listing that same Fac No. 3540 is an earlier brass era part.
My review has been observing original '26-'27s and some have this bump out style, the flat ones being earlier. IMO.
Post by TRDxB2 » Thu Dec 19, 2019 9:56 am
Check it out on EBAY. Its a Make Offer - asking $49 + $7.99 ship. Bet they could be had for $35 + ship
Model T Ford Top Clamp Touring Windshield Stantion Thumb Screw Wing 12 13 14 15
Post by RajoRacer » Thu Dec 19, 2019 10:26 am
I don't believe those are Ford parts - those year tops don't clamp to the w.s. - they utilize a strap & hook to the w.s. hinge !
Post by TRDxB2 » Thu Dec 19, 2019 12:04 pm
Was only thinking about the thumb screw. Now in comparing to the others they are NOT the same.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Thu Dec 19, 2019 4:47 pm
My 24 has the style shown in Frank’s picture on the left. I can’t say it’s “correct for the year”, but I believe it’s an original.
