Rebuilding my 24 T I opted to install a high compression head.  I noticed that the spark plug does not travel down as far on the high compression head as the low compression head. Is this normal? On the low compression head the plug comes flush with the bottom of the head.  One the high compression head it sits up approx 1/4 + or-.
Thanks for any help
Dino
						plug distance in high compression head
RichardG
- Last Name: Grzegorowicz
Re: plug distance in high compression head
DINO, YOU HAVE A FOUR STROKE ENGINE IN A MODEL T,  PLUG DEPTH  HAS NO BERING ON HOW YOUR ENGINE WILL RUN ,THE  INTAKE STROKE, THIS IS WHERE THE GAS IS PULLED INTO THE COMBUSTION  CHAMBER, THEN COMPRESSION  STROKE TAKES PLACE, THIS COMPRESS'S THE MIXTURE, THE CHAMBER IS FILLED WITH THIS MIXTURE UNDER HIGH PRESSURE, SO NO MATTER WHERE THE PLUG IS LOCATED THE SPARK FROM THE PLUG WILL IGNITE THE MIXTURE, FORCING THE  PISTON DOWN, AND ON ITS WAY BACK UP ITS FORCING THE SPENT GAS OUT THE EXHAUST. THIS TAKES PLACE WITH EACH OF THE FOUR  CYLINDERS, IN INSTALLING A HIGH COMPRESSION HEAD DID YOU CHECK THE CONDITION OF THE ROD BERGS AND MAINS ? this head will put  a heavy load on those parts, if there not in the best of shape.you may also get piston slap if the bores are worn. hope this helps, t---eees are fun.
				marinelli
- First Name: dino
- Last Name: marinelli
- * REQUIRED* Type and Year of Model Ts owned: 1924touring
Thanks Richard, I was not sure about the distance.  Regarding my rebuild, everything on this car will be completely rebuilt or restored.  Antique engine bearing in Escondido did all the rods and mains.  Mesa machine did all the machine work and Ed Katzorke did the transmission and Ruckstell rearend.  All new part and pieces from Snyders and Chaffins, the wood in the body was done by The Craftsman Ray Wells and the new wood wheels are done by Daves wood Wheel. Iam just putting the whole thing together.  Still have a long way to go but making sure I am doing it right.
