New tool
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
New tool
Out of 7 output shafts 4 had loose r404F477D20A2ABC2.jpeg[/attachment]
- First Name: Joe
- Last Name: Bell
Re: New tool
And they are usually the 26-7 ones!
- First Name: DEAN
- Last Name: YODER
Re: New tool
They were all 26/27 . Why do they fail? Wider brake bands??
- Last Name: Hatch
Re: New tool
Dean: What I have been finding is that if the rivets are not loose then the driven plate will be cracked. Does not matter if wide or narrow.
I think it has to do with 4th main alignment. Pan straightness.
- First Name: Jim
- Last Name: Eubanks
Re: New tool
I had the same problem and had a hard time finding a replacement, finally got one off ebay. I am tempted to re rivit the old one and weld it.
- First Name: DEAN
- Last Name: YODER
Re: New tool
I just received oversized rivets. I will drill and er rivet should be better than new.
- First Name: Les
- Last Name: Schubert
Re: New tool
The problem you are talking about is why I developed the “floating transmission shaft “. It significantly reduces the loads.
Dan Hatch is who I have licensed to make it.
