New tool
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
New tool
Post by D.Yoder » Mon Jan 06, 2020 4:55 pm
Out of 7 output shafts 4 had loose r404F477D20A2ABC2.jpeg[/attachment]
Rivet removing anvil
Rivet removal anvil
Rivet removal anvil
Joe Bell
First Name: Joe
Last Name: Bell
Re: New tool
Post by Joe Bell » Mon Jan 06, 2020 5:12 pm
And they are usually the 26-7 ones!
D.Yoder
First Name: DEAN
Last Name: YODER
Re: New tool
Post by D.Yoder » Mon Jan 06, 2020 5:47 pm
They were all 26/27 . Why do they fail? Wider brake bands??
Last Name: Hatch
Re: New tool
Post by Dan Hatch » Mon Jan 06, 2020 7:14 pm
Dean: What I have been finding is that if the rivets are not loose then the driven plate will be cracked. Does not matter if wide or narrow.
I think it has to do with 4th main alignment. Pan straightness.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Re: New tool
Post by Jim Eubanks » Sun Jan 12, 2020 10:07 am
I had the same problem and had a hard time finding a replacement, finally got one off ebay. I am tempted to re rivit the old one and weld it.
D.Yoder
First Name: DEAN
Last Name: YODER
Re: New tool
Post by D.Yoder » Sun Jan 12, 2020 1:31 pm
I just received oversized rivets. I will drill and er rivet should be better than new.
Les Schubert
First Name: Les
Last Name: Schubert
Re: New tool
Post by Les Schubert » Sun Jan 12, 2020 1:50 pm
The problem you are talking about is why I developed the “floating transmission shaft “. It significantly reduces the loads.
Dan Hatch is who I have licensed to make it.
