1915 hood former bolts
Randall strickland
Topic author - Posts: 158
- First Name: Randall
- Last Name: Strickland
Needing the two large head bolts that hold hood former to to body. I looked in all the catalogs and can’t find
Re: 1915 hood former bolts
I believe those are regular carriage bolts, available at any hardware store. You will have to grind and buff the modern markings off the heads and strip off the cad plating before you paint them.
HornsRus
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
those are called step bolts . they are available, i have 100s.charley
- Last Name: Strange
Don't step bolts usually have a somewhat larger diameter, but shorter height head on them than the equivalent carriage bolt?
Is this one close enough to the right size? Or perhaps a similar one of their's. I have no connection other than having bought from them.
https://www.restorationstuff.com/ecomme ... ts_id=1587
HornsRus
- Last Name: Shaver
fastenal, has them $0.50 each.you can see the imprint on the hood former. charley
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
I have nos ones, Bob
Randall strickland
Thanks fellows got two on the way !!
