Steering column and control rods
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Thu Jan 09, 2020 2:51 pm
Trying to figure out how to remove the rods. Don’t tell me all I need to do is bend these ears?
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Steering column and control rods
Post by dmdeaton » Thu Jan 09, 2020 2:53 pm
Post by Rich Eagle » Thu Jan 09, 2020 2:55 pm
If you anneal the ears they will bend easier with less chance of breaking.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Thu Jan 09, 2020 2:59 pm
The gear box looks like one piece?
So bending them is the way it’s done?
If so,yes I will anneal
Last Name: Strange
Post by CudaMan » Thu Jan 09, 2020 3:00 pm
Since you have the later single piece gear case, yes, you have to bend the ears (after annealing them so that they don't break).
Folks with the earlier two-piece gear cases could grind off the rivets holding the two parts of the case together and slide the rods out without bending the ears.
http://www.mtfca.com/discus/messages/70 ... 1493740470
http://www.mtfca.com/discus/messages/82 ... 1531404752
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Thu Jan 09, 2020 3:02 pm
K
Thanks guys
Post by Scott_Conger » Thu Jan 09, 2020 3:07 pm
anneal, let it cool to room temp, bend a very little bit...repeat a lot of times
multiple annealings followed by thorough cooling during the process is mandatory, in my experience. It takes very little material movement for the metal to become very brittle again.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Thu Jan 09, 2020 3:36 pm
Cut the rods off. Going to clean this stuff up. Sandblast the rust and then anneal
dmdeaton
First Name: Danny
Last Name: Deaton
I love bringing this stuff back to life
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Thu Jan 09, 2020 4:08 pm
To anneal a non-ferris metal, copper, brass, bronze heat to cherry red and quench in cold water, non ferris is hardened by cooling over long periods of time, the longer the harder. Non ferris will work harden and may require to be re-annealed during the working process. Iron is the opposite process, except will also work harden, they call it metal fatigue.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Thu Jan 09, 2020 4:42 pm
We take brass sheet and anneal it so we can beat it into a buttplate for flintlocks. Easy to work but like you said, starts to harden back up after you work it.
Post by Scott_Conger » Thu Jan 09, 2020 6:00 pm
Good that you are acquainted with working brass. Just know that you're used to working with brass that is alloyed for what you're doing, and this has a very different grain structure than you're used to. It will kick your butt if you're not careful. Knowing brass gives you a leg up but be careful to not get cocky! You'll be fine if you go slow.
Post by Original Smith » Fri Jan 10, 2020 11:15 am
I assume you have a better pair of control rods to use?
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Jan 10, 2020 3:48 pm
Yes, new set of rods and all the small parts. I will post more pics as I progress
