26 gas tank
Ed Donnelly
Topic author - Posts: 11
- First Name: Ed
- Last Name: Donnelly
- * REQUIRED* Type and Year of Model Ts owned: 25tt, 26roadster, 26coupe, 24touring, 26roadster pu
26 gas tank
Need a source for 26 gas tank weld in inlet fitting. I'm replacing several anf need help.
- Last Name: Humble
Re: 26 gas tank
No new sources, you will have to salvage from another tank.
jbond
- First Name: Herb
- Last Name: Spies
- * REQUIRED* Type and Year of Model Ts owned: 24 Model T camper, 27 Touring
Re: 26 gas tank
I got a used but excellent 27 tank from :
http://bobsantiqueautoparts.com/
Wash out a few dead mice and it was good to go.
Ed Donnelly
- First Name: Ed
Re: 26 gas tank
Well the suppliers are getting newtanks for 09's -27 from somebody. I'm sure mfg. Overseas, but the weld in fittings are what I'm needing.
Ruxstel24
- Last Name: Hanlon
Re: 26 gas tank
I have a pretty decent original tank....
Re: 26 gas tank
Actually Ed, the gas tanks are made in the U.S. - bad news is no one is reproducing '26-'27 cowl tanks !
John.Zibell
- Last Name: Zibell
Re: 26 gas tank
As far as I know, no one is making 26/27 cowl fuel tanks. So no new production of the fitting the sediment bowl goes into. You could salvage one from a bad tank, or fabricate your own. The thread is 1/2 inch pipe thread. You would have to make up some type of collar to fit the pipe thread piece to the tank. The metal is thin, so the part would have to be soldered or brazed to the tank.
1926 Tudor
Ed Donnelly
- First Name: Ed
Re: 26 gas tank
Hey Steve, who is the manufacturer of the 25 and earlier tanks? They too will work and yes they are soldered.
Re: 26 gas tank
I don't have his name but he's in Arkansas, I believe - Donnie Brown knows him & he's on here - maybe he can supply it.
Re: 26 gas tank
I don't know if there are differences in the '26 gas tank inlet looks like but this is from an earlier tank. It was soldered in. Something I can part with.
- Attachments
- IMG_0640.JPG (47.24 KiB) Viewed 5554 times
Ed Donnelly
- First Name: Ed
Re: 26 gas tank
Thank, but I'm looking for a quantity supplier so I may do local repairs.
