Ford Model K in 1998 at Sandwich, IL Show
WayneJ
Last Name: Jorgensen
Post by WayneJ » Tue Jan 21, 2020 11:57 pm
    I attended a car show in Sandwich, IL on the last Sunday in May of 1998 and took these photos of a Model K, and thought they might be of general interest:
    Wayne Jorgensen, Batavia, IL
    1918 Runabout
    RustyFords
    First Name: Don
    Last Name: Allen
    Re: Ford Model K in 1998 at Sandwich, IL Show
    Post by RustyFords » Wed Jan 22, 2020 1:32 pm
    It's always a source of interest for me to see Mustangs at car shows in the 80's and 90's. They were 20 to 30 year old cars at the time.
    We bought them cheap used them up and wrecked them when I was in high school in the 80's. Here's a cherry original fastback that my dad and I stripped the interior out of and made into a 1/4 mile drag car in 1986. We really lightened it up, installed a thoroughly worked over small block with some of the coolest heads I've ever seen and got it into the 11's.
    The K Ford is cool. I'm always amazed at the big, early brass cars. They're impressive to behold in person.
    1924 Touring
    WayneJ
    Post by WayneJ » Thu Jan 23, 2020 10:59 am
    I showed the photo of the engine compartment to a friend, and he wanted to know what the wooden box just in front the engine block is?
    I am sure someone hear has the answer.
    Thanks.
    1918 Runabout
    Post by Rich Eagle » Thu Jan 23, 2020 11:03 am
    I assume he means the brass mechanical oiler.
    WayneJ
    Post by WayneJ » Thu Jan 23, 2020 11:08 am
    Yes, I see now it is brass, not wood. Thank you for the quick response.
    1918 Runabout
    Post by Rich Eagle » Thu Jan 23, 2020 11:28 am
    Here is a photo of a McCord. The old brass can resemble wood can't it?
    Rob
    First Name: Rob
    Last Name: Heyen
    Post by Rob » Fri Jan 24, 2020 10:28 am
    Thanks for the post Rich. I’ve seen this K before, and had information about it’s incredible life after 1921. However, this thread forced me to do a bit more research and this time I found the original owner too. As a result, we now know the whereabouts of this car from it’s build date in 1908 up today. If you don’t mind I’ll tell that story on your thread. It’s fairly lengthy, and tells about a Model K that was a daily driver until 1921, and then ran and was registered regularly until 1940. Today it is on display at the Crawford Auto-Aviation Museum is a collection, Cleveland, Ohio, part of the Western Reserve Historical Society. Below is a photo of the car is it appears today:
    theautocarist
    First Name: Stephan
    Last Name: Walker
    * REQUIRED* Type and Year of Model Ts owned: Former owner 1906 Model N Ford
    Post by theautocarist » Fri Jan 24, 2020 10:51 am
    Hi Rob...the model K in the first 3 photographs of Wayne's post attending the 1998 Sandwich IL Show is the Ex Cecil Church car.
    Post by Original Smith » Fri Jan 24, 2020 10:58 am
    Why do they always varnish the steering wheel? I would think they would have been black?
    Rob
    First Name: Rob
    Last Name: Heyen
    Post by Rob » Fri Jan 24, 2020 11:01 am
    Stephan,
    Darn, you’re right. And I used to own that car....... :shock:
    When Cecil Church owned the same K, it didn’t have side aprons, so I thought it was the Cleveland K when I saw the older photo. Looking closer I see the air pump that was on the running board, and red leather front apron.
    Rich, never mind......
    thanks Stephan.
    Rob
    First Name: Rob
    Last Name: Heyen
    Post by Rob » Fri Jan 24, 2020 11:04 am
    Larry,
    Good question. Both our N and this K had stripped and varnished steering wheels. I believe our 13 T did too (memory?). I guess sometimes restorers thought it looked better.
    Rob
    First Name: Rob
    Last Name: Heyen
    Post by Rob » Fri Jan 24, 2020 11:05 am
    I meant to ask Wayne about posting more on this thread, and Rich about another thread. I think I need more coffee this morning. Or maybe the coffee needs a little “doctoring...”
    Herb Iffrig
    First Name: Herb
    Last Name: Iffrig
    Post by Herb Iffrig » Fri Jan 24, 2020 12:40 pm
    I did notice too, that the brass script is different on the radiators on the cars.
    Would one be more correct that the other? I have seen it both ways
    Rob
    First Name: Rob
    Last Name: Heyen
    Post by Rob » Fri Jan 24, 2020 2:25 pm
    Herb, I’ve seen a few different styles on “original” Model K. I’ve also seen on in block letters. There are a few K in museums with lower case “ford” in cursive, but they are actually “Garford” script with the “Gar” removed.
    Formerly “Garford”
    Another (Gar) Ford:
    A real “Garford”
    For only $185 plus shipping, you can own a “Garford” or “Ford” script:
    It's Bill
    First Name: Bill
    Last Name: Hoffer
    Post by It's Bill » Fri Jan 24, 2020 6:21 pm
    The Ford radiator script on the car at the top is a very well done graphic. Is it a real Ford design? Did the Ford logo change during the early years, and are there records of the changes?
    Cheers, Bill
