Headlight plain glass lens thickness?
				schwabd1
- First Name: David
- Last Name: Schwab
I need to have a couple plain glass headlight lenses cut. What is the correct thickness?
Re: Headlight plain glass lens thickness?
I believe I got the next size thicker than regular window glass. I don't know exactly how thick that is, but it's been fine.
				Mark Osterman
- Last Name: Osterman
Need a glass circle cutter?
				schwabd1
- First Name: David
- Last Name: Schwab
"I believe I got the next size thicker than regular window glass."
I've got some of that around the shop.....I figured it needed to be thicker than that. THANKS!
				schwabd1
- First Name: David
- Last Name: Schwab
I don't have a circle cutter, I figure if double strength is thick enough I should be able to "freehand" that OK.
I needed a lens cut for a speedometer. Hardware store butchered a piece of window glass (were going to charge $5). Went to a local stained glass hobby/window maker - used "lens glass" its thicker- made a perfect circle and ground the edges smooth for $5.  I have the knowledge, experience, tools and time to do it (circle cutter, glass grinder, was a hobby, retired) but for $5 that included the material - why would I. Check it out you may have a glass shop nearby.
Those clear lens are  'round' and are about 1/8" thick.   The round fit best with the 'clip' style retainers in the headlamp rim. Those are early style steel rims.
If using the H lens style rims, those are made with little tabs that rest against a squared off edge on the glass. That is a feature of the fluted Ford H lens. So your clear lens needs to be shaped with 4 flat areas to fit into those style rims.
Clip style rim for round lens
H Lens rim
H Lens rim
