Genrator block off Casting
Topic author - Posts: 63
- First Name: Kurt
- Last Name: Baltrusch
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1918 Touring, 1922 Sedan
There has been some discussion recently on the 1919 era cars that came without starters and generators, and that some of these cars came with a block off plate that eliminated the generator casting, This part made the engines look like the older blocks before they just started putting the 3 holed metal plate over the generator casting. I recently picked up some parts that included what look to be never used castings, T1769, which leads me to believe that these were available for purchase into the 20s. Any ideas on that?
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Re: Genrator block off Casting
Kurt:
I imagine that the Ford garages would have occasion to install these when they replaced a engine block in later years … I have 2 of these , so I guess that it was not uncommon to have to replace an engine due to wear or freeze cracks … could happen real easy here today since it is only 10 deg F now and was at 0 deg. last night … always an optimist ...Gene French
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
In case someone isn’t familiar with the block off casting being referenced, here’s a pic of one. P/N T1769
- Last Name: Hatch
I have had some that were NOS. Got them from Ford dealer stock. I am sure they were sold till the end of T times. Dan
