Rocky Mountain brakes
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Sat Feb 08, 2020 4:42 pm
Is it possible to get these things to not drag?
Re: Rocky Mountain brakes
Post by Scott_Conger » Sat Feb 08, 2020 6:10 pm
Not really, but if it is truely noticable ao a real extent, then something is maladjusted, which may be why you're asking.
For starters, I'd move the stay bars back and retighten the lock nut. They should not be set with zero clearance on the brake band tabs. The bands should be able to float fore/aft on them in all circumstances from fully "off" to fully "on".
Post by RajoRacer » Sat Feb 08, 2020 7:48 pm
Scott - the installation & adjustment docs. that come with the repro R.M. brakes from Bud say to adjust them just as Don has them. The instructions also state to attempt to set a clearance of approx. .030 all around which involves slight manipulation of ALL the mounting & hardware points !
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Feb 08, 2020 8:00 pm
Your rear supports are a little to perfect. Need to loosen the nut and recenter in the slots. This should do the trick.
Hope this Helps,
Hank
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Sat Feb 08, 2020 9:30 pm
Thanks I’ll give it a shot.
Last Name: Wrenn
Post by TWrenn » Mon Feb 10, 2020 5:49 pm
An item to not overlook is the brake rods. I was able to get mine pretty much drag free by a lot of tweaking of them but seem to be great now.
