Hello Gentlemen,
With the help of the club workshop, the Ruckstell was able to go back together.
I put the axle tube half's together with just the paper gasket.
Is this ok? or should I have used a sealer? My concern is that, it seems that the tolerances are very tight and I don't want to mess things up.
For instance adding the paper gasket/spacer to the pinion bearing was just enough to bring it into alignment.
Do I need a gasket around the Ruskstell shift block?
I didn't get one with the gasket set. I might have ordered the wrong set.
When I pulled the U-Joint from the axle, the pin came out in three pieces.
Did I do something wrong with the pining of the end?
Here is the pic of the pieces.
Rear end questions
Mustang1964s
Topic author - Posts: 271
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Kenny Edmondson
- First Name: Kenny
- Last Name: Edmondson
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Re: Rear end questions
I don’t use a paper gasket on the housing halves. Only use ultra-black on those. That way you can bolt stuff together to get clearances set correctly then add the sealer when done. There is a gasket for the ruckstell shifter and I’ve always used those. I’m not sure what happened with your ujoint pin.
- Last Name: Humble
Steve, regarding the paper gasket, yes apply a thin layer of permatex 2b non hardening gasket sealer together with the paper gasket.
Just assuming the u-joint was original and was in original drive shaft. The rivet pin could have been fractured over time if it wobbled in a worn drive shaft hole. Assume you checked the i.d. of the drive shaft hole for roundness and fit of a new rivet pin. They have to fit snug on insertion, then rivet over the ends to retain that pin.
Mustang1964s
With the new drive shaft. The u-joint and the pin was really snug.
I'm just a grease can away from getting back on the road.
