weight of Model T engine
stove bolt
First Name: Patrick
Last Name: Tooke
Post by stove bolt » Sat Feb 22, 2020 8:34 pm
I can't seem to find the weight for the model T's engine
The Pientpol Sky Scout plane was developed for it, as it was too heavy for his Air Camper, which used the motel A engine.
I'd guess you folks are the ones who'd know
Thanks Pat
First Name: Dallas
Last Name: Landers
Re: weight of Model T engine
Post by Dallas Landers » Sat Feb 22, 2020 8:57 pm
There was a thread on the weight of T engine for shipping I think. I cant seem to find it.
FreighTer Jim
Last Name: Jarzabek
Board Member Since: 2008
Link Here
Post by FreighTer Jim » Sat Feb 22, 2020 10:19 pm
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
stove bolt
First Name: Patrick
Last Name: Tooke
Post by stove bolt » Sun Feb 23, 2020 1:07 am
Thanks Jim
I got 291.15 lbs. for a long block/no trans
now to find the Covair engine weight, that should be easier.
They're still using them in airplanes.
Trford
First Name: Thomas
Last Name: Ford
Post by Trford » Sun Feb 23, 2020 9:33 am
Have you considered VW? Dual ignition heads are available. We used one in the late 70s on an experimental plane.
Post by TRDxB2 » Sun Feb 23, 2020 10:22 am
Thanks Jim
For VW engine GOOGLE VW plane engine
http://www.vwaircraftengineconversions. ... vices.html
Corvair engine weight 205lbs You'll love this site!! http://www.flycorvair.com/corvair.html
"Every day I answer the question: "What is the maximum amount of reliable horsepower I can get from a Corvair motor?" My extensive testing over the years indicates it is 100-120hp with the degree of reliability necessary for flight engines. ......"
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sun Feb 23, 2020 10:42 am
550 lbs. on a pallet, have shipped many of them.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Sun Feb 23, 2020 11:01 am
Neighbor cut a volkswagon engine in 2 and started a 2 cylinder airplane project but never finished it.His 4 cylinder volks powered plane was finished but never flown and is rotting out in the yard.
I just can't get past the idea of flying IN THE AIR,behind a volkswagon engine that sounds like a bucket of chinese made chains :shock:
All these T engine blocks people are hauling for scrap because of water jacket cracks,you should be able to get them cheap and knock all the water jacket off them.I saw it on 1 engine,looked like crap on a shingle but I guess it worked back in the day.
FreighTer Jim
Last Name: Jarzabek
Kansas VW Experimental Aircraft
Post by FreighTer Jim » Sun Feb 23, 2020 2:24 pm
I never equated Kansas with aircraft history until I met Grant
who grew up in Wichita and flew experimental aircraft powered
by VW engines while he was growing up.
Cessna started in Kansas - Boeing has had a presence there
for many years.
He was a commercial pilot for Alaska Air for (30) years.
A very nice - intelligent - friendly guy.
PM me or call me @ 260-804-6695 if you want his number.
FJ
stove bolt
First Name: Patrick
Last Name: Tooke
Post by stove bolt » Sun Feb 23, 2020 6:11 pm
Thanks for the replies guys, ford guys are always good guys.
To put this in context, I'm building free flight models, powered by rubber bands.
Some of those fellows are real sticky about "true scale", turns out Corvair engines have been used in the Sky Scout. I could explain more but on a off topic spot.
I am a Ford guy though, put a Scatt stroker kit in a 90 Lincoln small block. Dropped into my 49 Chev, fun. At the drag strip the chevy guys wouldn't talk to me, Ford guys love it.
Thanks again Pat
Oh I came up with 245 lbs., 46 lighter than the model T.
