1911 floorboards
Topic author - Posts: 509
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
1911 floorboards
Can someone give me the measurements or post pictures for the notches in the front floorboard for an 11 Touring to clear the bottom of the steering column and the back of the engine head and speedometer cable? I have new floorboards with no notches so they will not fit without hitting the rear of the engine. The picture of floorboards on the langs site shows notches. Thanks, Art
- First Name: Don
- Last Name: Poffenroth
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring 55276
Re: 1911 floorboards
Art,
I will get you pictures and measurements late tomorrow afternoon from my largely original 1911, 55276.
It’s stored elsewhere for the winter but I will be there after noon.
Don
Don
1911 Touring #55276
- First Name: Art
Thanks! Art
- First Name: Don
Ok Art,
From the drivers side the cut out for the block is about 12.5 inches in and about 4.25 inches wide, centered. It is about an inch deep, cut vertical.
The cutout for the speedometer is 3.75 inches in from the pass side. 1 inch wide, 3inches deep cut vertical.
Make sense?
Don
Make sense?
Don
1911 Touring #55276
- First Name: Art
Don, Got it! Thank you, Art
