Spark plug thread
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Spark plug thread
Post by ABoer » Wed Mar 04, 2020 3:08 am
Hi all ;
Two day's ago I picked up an Model T engine with # 70784 .
I think that must be october 1911 .
But the cyl. head has 18 mm sparkplug thread .
Some time in the past I have read about that .
Do one of you can tell me why ???
Toon
Re: Spark plug thread
Post by Wayne Sheldon » Wed Mar 04, 2020 4:06 am
Well, I do hope someone more familiar with this particular subsection of model T history can/will chime in here. If I recall correctly, the 18mm spark plug thread was unique to either English or European model Ts. Hence in Netherlands.I do not recall for how many years. Looks like a fantastic engine to get!
Last Name: Strange
Post by CudaMan » Wed Mar 04, 2020 7:53 am
ABoer
Last Name: Boer
Post by ABoer » Wed Mar 04, 2020 3:30 pm
Mark S ; Thank you very much for clearing up my memory .
Toon
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Mar 05, 2020 3:21 pm
Very interesting engine. Would you mind posting pictures of the other side and from the rear/front please?
It is intriguing to play "spot the detail differences" between a European built engine and Canadian ones we have in New Zealand.
So far:
hot air pipe,
valve chest covers,
wing nuts fasteners on covers,
oil filler cap,
front casting detail around oil filler,
engine number placement,
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Mar 06, 2020 2:08 am
Adrian,
Those are all characteristics of a late 1911 engine. Including the seven rivet pan (which should have a small reinforcement on the bottom by the fourth main) and the bottom inspection covert will have an embossed outer edge. The hot air pipe is the style used from about 1913-1915. The 1911 hot air pipe would have been cast iron.
Toon, is there a date (month and day) numbers by the center head bolt?
Keith
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Fri Mar 06, 2020 5:37 am
Toon dat is weer wat aparts dat je hebt opgedoken ! ;)
Groeten, Leo
Leo van Stirum, Netherlands
Post by RajoRacer » Fri Mar 06, 2020 11:09 am
Keith - I was under the impression that the "heavily crimped" pipe was '12 and the other "not so" were the '13 - '15 style.
Walter Higgins
First Name: Walter
Last Name: Higgins
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout
Post by Walter Higgins » Fri Mar 06, 2020 11:19 am
Good find! It looks like a whole maintained 1911 engine with service updates, like the later fan assembly. Neat that it still has a dogleg intake and wing nuts. Does the exhaust manifold have "T511" on the center-inside facing the head and, if so, is it prominent or smaller and harder to read?
