steering arm question
John Illinois
Topic author - Posts: 173
- Last Name: Burgett
Does the steering/pitman arm fit on a tapered shaft or straight shaft. How much force does it take to tap it off the steering shaft.Thanks.
John
John
Re: steering arm question
On the cars I have worked on the steering shaft is tapered and has a woodruff key in it. I have used a puller to remove it. If it is loose enough to tap off, it is too loose.
The parts book shows the same arm for all years, so they are all tapered. I don't have a puller that fits, so I bash them off with a brass drift and a BFH. Sometimes they come off easy, and sometimes they don't.
John Illinois
The manual says tap it. off. I Suspected it might be a little more than that.
Thanks,John
Thanks,John
FATMAN
- First Name: ROBERT
- Last Name: BERGSTADT
Heat it up with pen. oil, let cool tap off, seems to work better this way, Bob
TonyB
- First Name: Tony
- Last Name: Bowker
While I agree all steering arms appear to have a taper, they are not all the same. I believe the very early Ts with a short steering column use a different angle than later models. I suspect the 1912 torpedo used yet a different design and I suppose the Improved cars yet another.
I didn’t take this picture but two years ago I was very interested in such items and saved a picture from an earlier thread.
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Dennis
- Last Name: Seth
Tony,
I guess in one way or the other you took the picture!
