Speedometer cable fell off.
Spade
Topic author - Posts: 25
- First Name: Curtis
- Last Name: Fesler
- * REQUIRED* Type and Year of Model Ts owned: 1923 Fordor
Yesterday I went for a drive and noticed my speedometer quit working. Its on a 1923 Fordor. When I put the car away I could see that it slipped off and was laying across a tie rod and appears to be undamaged. I see the worm gear and it looks good. I haven't waded through the grease yet to see how its attached or how to put it back on. Is there a magic trick to make it stay on?
Stephen_heatherly
- First Name: Stephen
- Last Name: Heatherly
Re: Speedometer cable fell off.
It should have a nut that screws onto the output of the swivel drive.
Stephen
Stephen
Make sure the slot and key are lined up when you screw the nut back on.
Can you post a photo ? Some Stewart drives had a tapered pin holding the swivel halves together rather than a threaded bolt & nut.
