strange tbay engine
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
strange tbay engine
Post by Jim Eubanks » Tue Feb 05, 2019 5:23 pm
Can someone shed some light on what this is? eBay item number:233121661169 Never seen anything like it and it appears to be a mfg thing. It sure does not appear to be a diesel with spark plugs, mag and carbs.
Last Name: Gregush
Re: strange tbay engine
Post by Mark Gregush » Tue Feb 05, 2019 5:25 pm
Jim Eubanks
First Name: Jim
Last Name: Eubanks
Post by Jim Eubanks » Tue Feb 05, 2019 9:00 pm
There has to be someone out there that knows about this and how it was used. Anyone that could build this thing sure could do magic to other engines.
Last Name: Gregush
Post by Mark Gregush » Wed Feb 06, 2019 12:07 am
Try opening the link. It is already being talked about.
Jim Eubanks
First Name: Jim
Last Name: Eubanks
Post by Jim Eubanks » Wed Feb 06, 2019 7:04 am
I did read the link and it does not identify the origin, maker or positive history of the engine.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Feb 06, 2019 8:05 am
I had a 1965 2-cycle Sears Allstate motorcycle with two cylinders and one spark plug. It was a V-twin with the smaller rear cylinder used for intake and compression. The fuel charge moved through a passage to the larger front cylinder for power and exhaust strokes. The front had a spark plug and was connected to the exhaust pipe.
