26-27 license plate clamps
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Post by GG Gregory » Fri Mar 20, 2020 3:44 pm
Are the 26-27 license plate clamps that mount to the headlight bar the same as for a Model A ? I have a set for a Model A but the holes in the original 1927 Tennessee plate are set lower and I can’t attach it.
Dropacent
Last Name: Morsher
Re: 26-27 license plate clamps
Post by Dropacent » Fri Mar 20, 2020 3:52 pm
Same as the model A. Look for genuine ones, the reproductions are crappy
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Mar 20, 2020 3:58 pm
Anyone have an original they can post a picture of?
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Fri Mar 20, 2020 4:21 pm
Thanks, now to find a set !
Post by RajoRacer » Fri Mar 20, 2020 8:35 pm
I believe I have several sets - I'll look tomorrow.
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Fri Mar 20, 2020 8:46 pm
RajoRacer, let me know if you have a set to sell.
Post by Norman Kling » Fri Mar 20, 2020 9:05 pm
The placement of the holes on the plate should not be a problem. The correct way to place the brackets is to put the bolt to the top of the bar and bolt the plate on the front, not between the clamps. So it should work fine if you place it this way.
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Sat Mar 21, 2020 7:49 am
Thanks Norman I’m sure that would probably work but I’d rather Mount the plate the way it should be if possible.
Post by DanTreace » Sat Mar 21, 2020 10:53 am
Have found the reproduction A clamps to be satisfactory.
Here is Ford #15 millon with Ford accessory license clamps, note how they hang.
On this accessory bar, the clamps hang, and the bolt goes thru the license slot, period plate.
Or, if you found old aftermarket versions, they hang from the bar too. Plate below hanger.
And another old photo of period placement.
348170 (599x446) (2).jpg (113.6 KiB) Viewed 4043 times
GG Gregory
First Name: GG
Last Name: Gregory
Post by GG Gregory » Sat Mar 21, 2020 12:24 pm
Ahh, I see Dan! Thank you. I just assumed they should actually hang through the clamp itself like my 1930 Model A, guess not.
