26-27 license plate clamps
Topic author - Posts: 326
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Are the 26-27 license plate clamps that mount to the headlight bar the same as for a Model A ? I have a set for a Model A but the holes in the original 1927 Tennessee plate are set lower and I can’t attach it.
- Last Name: Morsher
Re: 26-27 license plate clamps
Same as the model A. Look for genuine ones, the reproductions are crappy
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Anyone have an original they can post a picture of?
- First Name: GG
Thanks, now to find a set !
I believe I have several sets - I'll look tomorrow.
- First Name: GG
RajoRacer, let me know if you have a set to sell.
The placement of the holes on the plate should not be a problem. The correct way to place the brackets is to put the bolt to the top of the bar and bolt the plate on the front, not between the clamps. So it should work fine if you place it this way.
- First Name: GG
Thanks Norman I’m sure that would probably work but I’d rather Mount the plate the way it should be if possible.
Have found the reproduction A clamps to be satisfactory.
Here is Ford #15 millon with Ford accessory license clamps, note how they hang.
On this accessory bar, the clamps hang, and the bolt goes thru the license slot, period plate.
Or, if you found old aftermarket versions, they hang from the bar too. Plate below hanger.
And another old photo of period placement.
- First Name: GG
Ahh, I see Dan! Thank you. I just assumed they should actually hang through the clamp itself like my 1930 Model A, guess not.
