Gasket making
Playswithbrass
First Name: Peter
Last Name: McIntyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
Gasket making
Post by Playswithbrass » Sat Mar 21, 2020 11:20 am
Running glass bowl stromberg carb and always had a problem with the cork gasket shrinking. Bought BUNA rubber nitrile gasket material and have been busy making a die and then gaskets. Will see how they hold up
Re: Gasket making
Post by Mark Gregush » Sat Mar 21, 2020 11:30 am
Nice job on the die. (For those that don't know, same with using a hole punch) When using it put a sheet of something like the plastic cutting board material under the material you are cutting, which is what you have done.
A piece hard wood would work too. You could also use the cork/BUNA nitrile gasket material, it is pretty shrink proof and holds up to modern gas.
Re: Gasket making
Post by Rich Eagle » Sat Mar 21, 2020 11:33 am
That is great to see.
Last Name: Patrick
Re: Gasket making
Post by jiminbartow » Sat Mar 21, 2020 11:49 am
In my experience, some types of rubber has been adversely affected by gasoline. Don’t be surprised if it swells, becomes misshapen and starts breaking down where it comes into contact with the gasoline. You may want to do an experiment and drop a piece of the gasket material into a jar can of gasoline (with a screw on lid, of course) for awhile to see how it reacts before using it for real in the fuel system. We wouldn’t want your T to become a fire hazard, especially if garaged close to your house. Be careful. Jim Patrick
Playswithbrass
First Name: Peter
Last Name: McIntyre
Re: Gasket making
Post by Playswithbrass » Sat Mar 21, 2020 12:17 pm
Jim buna nitrile is according to the manufacture impervious to fuel/greases and ethanol. So fingers crossed,have the gaskets installed,fuel in the carb and am waiting to see what happens.
Mark did not know about the cork/buna,went to the parts store but they knew of nothing go figure.
Back in the early 70's every spring with the hot rods etc running Holley,s you had to regasket because the gaskets would shrink,Holley finally used the material I would suspect you are talking about.Need to find a supplier for sheets of it
Cheers Pete
Last Name: Strange
Re: Gasket making
Post by CudaMan » Sat Mar 21, 2020 1:36 pm
Scroll down near the bottom of this page:
https://www.mcmaster.com/cork-gaskets
Playswithbrass
First Name: Peter
Last Name: McIntyre
Re: Gasket making
Post by Playswithbrass » Sat Mar 21, 2020 2:03 pm
Mark S good to know. Thanks
Last Name: Hatch
Re: Gasket making
Post by Dan Hatch » Sat Mar 21, 2020 2:07 pm
Be careful about the cork with buna. In the list it said for bulletin boards.
A few months ago I found a deal on rolls of cork with buna. The guy said they were for bulletin boards , but could be used for gaskets. I was looking to buy a couple 750 foot rolls and get the people that are making the paper T gaskets to make some out of the cork. Called the manufacturer, talked with plant manager. He looked up the part number and told me that since it was for bulletin boards not enough buna in them for gaskets.
Just a heads up guys. Dan
Last Name: Patrick
Re: Gasket making
Post by jiminbartow » Sat Mar 21, 2020 2:29 pm
Great. Just want you to be safe. I shoulda’ known you would have done your research beforehand. Jim Patrick
Re: Gasket making
Post by Steve Jelf » Sat Mar 21, 2020 2:34 pm
Peter, how thick?
Playswithbrass
First Name: Peter
Last Name: McIntyre
Re: Gasket making
Post by Playswithbrass » Sat Mar 21, 2020 4:33 pm
Jeff 3/16. Would of liked 1/8 but could not find. Bought it off Amazon
StanHowe
First Name: Stan
Last Name: Howe
Re: Gasket making
Post by StanHowe » Sat Mar 21, 2020 11:33 pm
I have been using some gasket material from the McMaster gasket assortment set that is about the same thickness as the original Asbestos gaskets were. They apparently don't sell it separately but it is vegetable fiber who it is impervious to alcohols.
I cut them on a gasket cutter and save the center cuts for making other small gaskets.
You can also use lead if you have 1/16 sheet, thicker will not compress well, in my experience.
