15 coil box switch
Wayne Mims
Topic author - Posts: 140
- First Name: Ervin
- Last Name: Mims
- * REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
15 coil box switch
I am putting together a 15 coil box and switch Lang's parts book shows three wires one going to mag one going to bat and one going to Common where does the common wire hook to I've never tore one of these apart so I have no idea your help would be appreciated thank you
Kerry
- Last Name: van Ekeren
Re: 15 coil box switch
Common would go to the coils.
John iaccino
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
The common would be connected to the bottom strip of the coil box witch is the bottom of the coils as stated above.
Wayne Mims
- First Name: Ervin
- Last Name: Mims
I know one in goes to the strip where does the other end go to the switch and where
Wayne Mims
- First Name: Ervin
- Last Name: Mims
John iaccino
The wire goes from the bottom strip of the coil box to one of the bottom screws of the switch
Wayne Mims
- First Name: Ervin
- Last Name: Mims
Thank you very much for the picture and the statement I was thinking that's where it went but I wasn't positive thank you again
