K R Wilson Oil Pan Straightening Jig
Topic author - Posts: 66
- First Name: Dale
- Last Name: McMurry
- * REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
Would someone be kind enough to furnish me a blueprint or pdf file with all dimensions to make one of these.
Help would be appreciated. Thanks Dale
- First Name: Steven
- Last Name: Husa
- * REQUIRED* Type and Year of Model Ts owned: 1926 model years
Re: K R Wilson Oil Pan Straightening Jig
Check with Jay Skinner in Long Beach CA.
562-426-5478 He collects paper and tools!
- First Name: Dale
Contacted Jay nice fellow. Thanks Steven.
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Could you post your findings for all to see please.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
I have a cast iron engineers surface plate, and would appreciate a map of the pan bolt holes.
- Last Name: van Ekeren
Got a spare 26/27 block and hogs? then bolt the 2 together and trace the bolt pattern to the plate and for the few that can't be got at lay a gasket on to find them.
Myself. I wouldn't go through the trouble of making one for the few I check, just use the 26/27 block and hogs as is, a length of exhaust pipe for a centre line and not hard to ruler the ears, front and back to check for specs.
...bolt the 2 together and trace the bolt pattern to the plate...
Excellent. I love that idea.
- First Name: Dale
Allan check the Jay Skinner lead posted above your post. Jay Skinner Thanks guys for all of the feedback
Dale
Dale
