Another Stevens tool for the collection
Topic author - Posts: 1413
- First Name: Donnie
- Last Name: Brown
I was able to add one more Stevens tool to the collection. It is not complete and probably not a real useful tool, but it has the original box. It is missing all 15 of the threaded inserts. If anyone has any of the inserts I would love to get at least one to put in the box.
- First Name: Andrew
- Last Name: Brand
Re: Another Stevens tool for the collection
What a nice item Donnie. Thanks for posting the photos. If you don't have any luck finding inserts, you could make some using old head bolts.
Andrew
Andrew
- Last Name: Humble
I have the same set with the inserts, I agree, it is not a very useful tool.
- Last Name: Brown
Andrew. Yes, I had thought about making a set. Its a long shot, but was hoping to find some.
Humblej, could you measure the overall length of your inserts. I can figure out the rest, but a length would help.
I disagree to their usefulness - I use mine whenever I need to clean off the top of a block AFTER cleaning the head bolt holes ! Simply install, clean the block surface, remove inserts & blow the holes out.
I'll send you a photo with dimensions, Donnie.
- Last Name: Brown
Steve, Thanks. I think they will be fairly easy to make. Ill just have to make a jig so all 15 will be alike ...
This is an original, Donnie.
And a few more of my smaller Stevens kits.
I'd a liked a wooden box kit - must have been an "early" version !
- Last Name: Brown
Thanks Steve. My kits are probably 1/2 wooden boxes and the other 1/2 are cardboard boxes.
