Trasmission bands
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Trasmission bands
Post by ABoer » Sun Feb 10, 2019 11:43 am
Hi : Is it possible to take out the transmission bands , when the demountable ears are on the right side .
Thanks for your answer .
Toon
Adam
First Name: Adam
Last Name: Doleshal
Re: Trasmission bands
Post by Adam » Sun Feb 10, 2019 11:45 am
Left or Right hand drive car???
Post by RajoRacer » Sun Feb 10, 2019 11:47 am
Yes BUT you need to get them one at a time back to the rear of the brake drum to get enough room to remove the ear then pull them out from the wrong side !
Last Name: Gregush
Post by Mark Gregush » Sun Feb 10, 2019 12:37 pm
I take all my bands out in this order brake, low and reverse. There is smaller overall area to work with at the rear of the hogs head. Slide them back, remove ears and rotate out to the right/passenger side (in this case). Never could grasp installing the brake band first line of thinking, better chance of getting them out of round starting at the big end.
