In the photo below, the clutch arms are retained on the shaft by bolts - not riveted.
This is in an aluminum hogshead without the reinforcing ribs (early).
What year hogshead would this be?
Early Clutch Arm Bolts
BE_ZERO_BE
Topic author - Posts: 655
- First Name: BOB
- Last Name: CASCISA
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Re: Early Clutch Arm Bolts
About june 1911- 1912/13 ish which would fit with non reinforced hogs head. Don't forget the shaft and arms are keyed.
BE_ZERO_BE
- First Name: BOB
Thanks Mark.
PDX wins again
PDX wins again
Be_Zero_Be
Be_Zero_Be
