Speedometer cable fell off.
Spade
First Name: Curtis
Last Name: Fesler
* REQUIRED* Type and Year of Model Ts owned: 1923 Fordor
Post by Spade » Thu Mar 05, 2020 10:33 am
Yesterday I went for a drive and noticed my speedometer quit working. Its on a 1923 Fordor. When I put the car away I could see that it slipped off and was laying across a tie rod and appears to be undamaged. I see the worm gear and it looks good. I haven't waded through the grease yet to see how its attached or how to put it back on. Is there a magic trick to make it stay on?
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Re: Speedometer cable fell off.
Post by Stephen_heatherly » Thu Mar 05, 2020 11:59 am
It should have a nut that screws onto the output of the swivel drive.
Stephen
Post by Mark Gregush » Fri Mar 06, 2020 12:18 pm
Make sure the slot and key are lined up when you screw the nut back on.
Post by RajoRacer » Fri Mar 06, 2020 1:12 pm
Can you post a photo ? Some Stewart drives had a tapered pin holding the swivel halves together rather than a threaded bolt & nut.
