Cowl id
Speedo1
Topic author - Posts: 25
- First Name: Mike
- Last Name: Kenney
Cowl id
Secondary to door I’d is this cowl section someone tried to make into a truck. I believe a 27: frame numbers are 27, and if cowl is original to frame, I’m not sure. The cowl door does have a stop that holds it open half-way open. This would make it a Fordor, correct?
Re: Cowl id
I'd have to search MTFCA but I believe there was a post about that Truck cinfiguration
Speedo1
- First Name: Mike
- Last Name: Kenney
Re: Cowl id
I’m sorry, about this particular one, or one similar?
Re: Cowl id
I didn't see the hole for gas filter.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Cowl id
The firewall has the opening for the fuel shut off valve and the two tank strap holes, so 26-27 coupe or tudor. Yes, the coupe and tudors had a gas door that would prop open for ventilation.
Speedo1
- First Name: Mike
- Last Name: Kenney
Re: Cowl id
Couple more photos. I’m my humble opinion, not a very good “ back-half” job, although I believe the rear window upper half is genuine Ford.
- Attachments
- B7AF85D3-8F17-415B-9C99-3D2EC1534CD9.jpeg (31.01 KiB) Viewed 3843 times
- 58BC1E28-8106-4318-A70F-84B5261BCE6F.jpeg (26.24 KiB) Viewed 3843 times
- 7853FE85-067F-4F44-B1D7-9E8003EF28B3.jpeg (30.54 KiB) Viewed 3843 times
- EA569372-B14C-4B38-98B5-1A80D44D58EA.jpeg (30.49 KiB) Viewed 3843 times
Mark Nunn
- Last Name: Nunn
Re: Cowl id
Fordors from '26-'27 did not have cowl gas tanks. That can't be from a Fordor.
Re: Cowl id
True but they did have a cowl vent.
Re: Cowl id
Cowl vent on Fordor will have bracket and handle under to operate from the front seat. Spring loaded, there may be remains if a Fordor.
Otherwise the cowl lid on the cars with gas tanks has only a clip hinge on the rear of the lid, to prop it and a second detent to fully hold it open for gas ups.
