Guys: Question, will dome pistons clear a low (early) head?
Thanks Dan
Dome pistons with Low Head?
- First Name: Henry
- Last Name: Lee
Re: Dome pistons with Low Head?
You will have to do some impression work with real soft clay Dan. Some will and some will not. I have had to in the past, machine down the pistons to get them right.
Just Sayin’
Just Sayin’
Les Schubert
- First Name: Les
- Last Name: Schubert
I run that combination in my 13. I did check carefully for clearance with NO head gasket!!
I was lucky in that the block and head didn’t need much surfacing
Topic author - Posts: 5279
- Last Name: Hatch
Thanks guys.
modeltbarn
- First Name: Gary
- Last Name: London
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring
I've done this in 4 engines. Only one needed a little flap disking in one cylinder for the head to lie flat on the block without a gasket. I haven't tried a 09-10 head, but my '11 is runnung an early 11 head with this. The other heads have been in the '14 and up variety.
Susanne
- First Name: Susanne
- Last Name: Rohner
Mine does... I'm running an earlier head (early '12) than motor (late '15) as the original head keeps developing cracks... but both cleared the pistons no problem!
