14 mm spark plugs
Jfmarkham
Last Name: Markham
* REQUIRED* Type and Year of Model Ts owned: 1923 pie wagon
14 mm spark plugs
Post by Jfmarkham » Mon Jun 22, 2020 3:42 pm
A while back I bought the 14 mm plug adapters but Lange don't tell you what plug you should use anyone using a 14 mm plug if so what make and number
ModelTWoods
First Name: Terry
Last Name: Woods
Re: 14 mm spark plugs
Post by ModelTWoods » Mon Jun 22, 2020 3:47 pm
I'm not sure whether the plug heat range makes a big difference depending on whether you are running an iron or aluminum head, but it might. Snyder's recommends using Champion RC12YC in their aluminum Model A head. From a previous discussion of this subject on the MTFCA forum, question posed by Mark Chaffin, the consensus of several post respondents was Bosch 4203. Three other mentioned were: Bosch 4501, Autolite 216, and Autolite 66.
Post by John kuehn » Mon Jun 22, 2020 3:48 pm
Lang’s list 14mm spark plugs along with the 14mm plug adapters. They are Autolite plugs. They list them on their web site and catalogue.
