Found this NOS part?
Last Name: Hatch
Post by Dan Hatch » Wed Jul 22, 2020 4:32 pm
Found this at bottom of bucket of parts I got a couple years ago. It is NOS, but who on here know what it is? I know it is nos because , they usually are torn up when removing.
This is one of a very few I have seen. Dan
Joe Bell
First Name: Joe
Last Name: Bell
Re: Found this NOS part?
Post by Joe Bell » Wed Jul 22, 2020 4:43 pm
Where your headlight wires go through the hood shelf.
Last Name: Hatch
Post by Dan Hatch » Wed Jul 22, 2020 4:44 pm
No, guess again.
Post by John kuehn » Wed Jul 22, 2020 4:47 pm
Starter armateur bushing on the brush holder end I think.
Last Name: Hatch
Post by Dan Hatch » Wed Jul 22, 2020 4:56 pm
Yes that is it. Thought you guys would like to see. Do not remember see any others. I do not use bushings any more, I replace them with ball bearings.
It goes into the parts bin. Dan
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Jul 22, 2020 11:03 pm
Does it have the flats on it to limit rotation?
Last Name: Hatch
Post by Dan Hatch » Thu Jul 23, 2020 11:00 am
No it is round. Dan
Post by John kuehn » Thu Jul 23, 2020 12:58 pm
Is it brass? The last brush end bushing I took out was made of some sort of pot metal or hard aluminum. Maybe Ford started using brass as a replacement material in their later parts to be used in production.
Last Name: Hatch
Post by Dan Hatch » Thu Jul 23, 2020 3:39 pm
No, not bronze. It is some heavy white metal, probably Babbitt. Not pot metal, too heavy.
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Thu Jul 23, 2020 6:30 pm
I got a box of them, perhaps a 100 or more. No value, the replacements are much better.
Ron Patterson
Post by Ron Patterson » Fri Jul 24, 2020 9:47 am
That Babbitt bushing is factory number T-1759 and was used in the Model T starter brush cap.
It was a common starter problem for several reasons. After factory installation where something very similar to Lubriplate was added there is no provision for further periodic lubrication. You commonly see starter brush caps modified for periodic oiling. When servicing the starter using this NOS part is difficult if you do not have the proper tools. The Allen Electric starter repair kit included a special driver and align reaming tool.
It is not clear why Ford used a Babbitt bushing in this application. Babbitt is great for radial loads, but not axial wear from the starter armature wearing into the face of the Babbitt eventually causing excessive armature end play.
The brass bushing sold today by Model T parts suppliers is a problem for the same reason; needs special tools for installation and no provision for periodic lubrication.
The best repair solution to all these problems is the one Dan Hatch commented upon and is a pre-lubed sealed ball bearing and spacer to entirely replace T-1759. Because of the low duty cycle of the starter that adapted modern solution will last another 100 years.
Starter End Play 001.JPG (40.24 KiB) Viewed 4036 times
Post by Original Smith » Fri Jul 24, 2020 9:59 am
Good write up Ron. I always enjoy your comments.
