Found something interesting?
Topic author - Posts: 5527
- Last Name: Hatch
I was parting out some heavy rods, you know saving rod bolts and pin bolts. When I noticed this on a set.
A full set of DB made rods. I have seen a lot of DB parts, first set of rods. Dates them to pre 13? What DB parts have you got? Thanks Dan
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Found something interesting?
Great find!
- First Name: Henry
- Last Name: Lee
That is a find Dan!
- Last Name: van Ekeren
Canadian engines still had DB heavy rods until 1916.
- Last Name: Hatch
I am sure they were used till they were all gone. Just like Ford did with everything. But did not ford stopped using DB for parts around 13?
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Dan:
i have a bunch of Dodge Brothers parts ... a complete 1925 touring car , a 1917 Roadster cut down and several chassis ... great cars , powerful and reliable ... always an optimist Gene French
John Warren
- Last Name: Warren
I have an engine in my 25rpu that was rebuilt when I got it. Before I ran it I took the oil inspection pan off to install dippers, if they weren't already. Three heavy rods and one regular rod with some flat washers making up the difference in weight. I... installed the dippers and put it back together. It is the smoothest engine I have been around. What are you going to do with the heavy rods, I would be interested. Thanks.
- Last Name: Hatch
John: Email me at address in pictures. I have some heavy rods.
Interesting post about the old style rods.
Without a doubt lots of the old style heavier rods were sent to the scrap yard over time.
Most vendors won’t take them for a core for rebabiting so the question would be what to do with them.
I have a few still around somewhere if I haven’t thrown them out.
Maybe some one would put together an engine with older style engine and transmission parts for originality someday.
Now that would be interesting!
Colin Mavins
- First Name: Colin
- Last Name: Mavins
The rods that came out of the 12 when I broke the crank were DB rods we put the light weight rods in I also have the cast pistons and pins that were changed 60 years ago Dad kept every part .
My '13 had the DB rods when I got it. That was in 1961.
Greg Griffin
- First Name: Greg
- Last Name: Griffin
- * REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
I put heavy rods and cast iron pistons back in my '14. Straight-cut timing gears, too. Oh, and my valve stems are not adjustable. Round tube radiator. My '14 is a '14! It's my idea of fun.
