Speaking of cranking !
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri Aug 21, 2020 2:30 pm
Has anyone ever run onto a crank arrangement like this one ? Any thoughts ??
"Get a horse !"
HPetrino
First Name: Henry
Last Name: Petrino
Re: Speaking of cranking !
Post by HPetrino » Fri Aug 21, 2020 2:42 pm
Really hard to tell, but upon enlarging it somewhat I'm thinking it's a spring loaded accessory. Wind up the spring, then release it to turn the engine over.
Of course, pure guess......
Post by RajoRacer » Fri Aug 21, 2020 3:13 pm
It appears to be a "Sandbo" hand starter.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Fri Aug 21, 2020 4:20 pm
Looks like he made the wife do the cranking. Hence the helmet and the missing RH headlamp...
Post by DanTreace » Fri Aug 21, 2020 4:50 pm
Steve named it!
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
Post by PDGx » Fri Aug 21, 2020 5:06 pm
Damm, need one of those for my Mack - with a 4’ vertical climb in and out every time :!:
http://www.cimorelli.com/mtdl/1914/1914 ... tarter.pdf
However, I doubt you could pull a recoil starter on it - especially from the seat.
(I won’t ever complain about hand cranking a T again.)
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri Aug 21, 2020 8:19 pm
Pretty nifty ! Apparently you could crank it "conventionally" from outside the car too. I wonder if the device entailed an anti-kick device ? Caption on the photo says "Carey, Idaho, 1917".
"Get a horse !"
