Removing the Steering Wheel
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Sun Sep 27, 2020 10:02 pm
Can the steering wheel be removed on a 1927 T with out a puller?
Re: Removing the Steering Wheel
Post by Mark Gregush » Sun Sep 27, 2020 11:35 pm
Yes, no, maybe all depends on how tight it is. ;)
Post by Allan » Mon Sep 28, 2020 7:36 am
The wheel is keyed on a parallel shaft, so there is no taper to break. If you sit in the car and load the wheel with pressure from your legs while tapping on the shaft with a soft faced hammer, it should come off. Or, you can remove the wheel/shaft/steering box cover as a unit, the same hammer can be used to drive the shaft out of the wheel.
Hope this helps.
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Wed Sep 30, 2020 1:41 pm
Allan, I did what you said and off it came! Thanks.
