Compression test
john in kzoo
Last Name: Seelman
* REQUIRED* Type and Year of Model Ts owned: 15 touring
Compression test
Post by john in kzoo » Fri Nov 13, 2020 11:30 am
Guys,
Interested in doing a simple compression test. A couple of questions 1. Warm or cold engine? and 2. All plugs out as each cylinder is being tested?
Mark Nunn
Last Name: Nunn
Re: Compression test
Post by Mark Nunn » Fri Nov 13, 2020 11:42 am
Don't forget to fully open the throttle during the tests. You can't compress air that can't get in.
Post by RajoRacer » Fri Nov 13, 2020 12:45 pm
1: I prefer warm - 2: yes & 3: what Mark said !
Post by Mark Gregush » Fri Nov 13, 2020 1:28 pm
It is ok to have the throttle closed or open, I really have never seen a difference between the two. I do my test cold, I am more interested in starting compression then running. Again, you can do them both to see how much difference between the two readings.
john in kzoo
Last Name: Seelman
Post by john in kzoo » Mon Nov 16, 2020 7:53 am
Compression test completed Saturday on a very cold engine (30 degrees) got 45#, 40#, 40#, and 40#. Plugs looked good #1 was sooty though
Thoughts??
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Mon Nov 16, 2020 1:31 pm
Run the wheels off of it or do a complete rebuild.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Mon Nov 16, 2020 1:52 pm
How to do a compression test on engine without starter ?
Super Mario Bross ;)
1911 Touring
1914 Speedster
john in kzoo
Last Name: Seelman
Post by john in kzoo » Mon Nov 16, 2020 1:54 pm
I opt for running the wheels off........
Quickm007 - Crank and crank and crank
Fire_chief
First Name: Charlie
Last Name: Gagel
Post by Fire_chief » Mon Nov 16, 2020 2:53 pm
Mario, it is still the same process.
The only thing different is that you get to turn the engine over with the crank
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Nov 16, 2020 2:58 pm
Your cold compression test numbers, 45,40,40,40, would sujest why #1 plug was sooty. You are getting a little oil past the rings in #1 and #1 plug has a intermitid misfire. Try doing a wet compression. test with a little oil in the cylendars and all numbers will come up, with #1 coming up the least. Your cold dry numbers of 40 lbs are not that bad. I would keep driving the car, keep up with your maintenance and check the #1 coil & timer connections, replace #1 plug if needed.
john in kzoo
Last Name: Seelman
Post by john in kzoo » Mon Nov 16, 2020 4:21 pm
Thanks Guys.....
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Mon Nov 16, 2020 5:59 pm
I much prefer comp testing a low comp engine like the T when it’s cold. It gives a truer situation concerning starting the T when cold. Testing hot will give a false reading regarding cold starting. A modern with a comp of say 150 lbs. or better is relatively in affected by a 5 or 10 lb. drop. On a T that could be the difference between easy starting or not on a cold day. Do a dry then a wet test with the choke & throttle wide open. Write the results down. Don’t trust to memory. A VERY informative test concerning your engines condition. Especially if you’re pulling the head for no reason.
Last Name: Juhl
Post by Oldav8tor » Mon Nov 16, 2020 6:23 pm
Sooo.... what is the "good" compression range?
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Mon Nov 16, 2020 6:30 pm
55 PSI would be nice...
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Tue Nov 17, 2020 9:34 am
Thank you guys, I will crank, crank and crank but my shoulder is painfull right now. Hope I will recover soon... :lol:
1911 Touring
1914 Speedster
john in kzoo
Last Name: Seelman
Post by john in kzoo » Tue Nov 17, 2020 11:00 am
It's really easy with all but one plug out and the throttle positioned all the way open as well
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Tue Nov 17, 2020 1:33 pm
Super Mario, Befriend a football player with wide shoulders and strong arms.... :)
Keith
