Chickasha list
Afrazer
Topic author - Posts: 148
- First Name: David
- Last Name: Frazer
- * REQUIRED* Type and Year of Model Ts owned: 1925 closed cab TT. 1925 factory roadster pickup. 1926 two door sedan
Chickasha list
With it in just two weeks I’m curious as no one has really posted about what they are taking of course I’m sure it looming over everyone’s head if it’s canceled again. But in the hopes it’s not is anyone going to chickasha with a 26-27 Tudor front and rear fenders,25-30 Ford tailgate, or shorten drive shaft, tube and rods for a cast iron warford.
1925 closed cab TT
1926 two door sedan
1926 two door sedan
Gene_French
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
Re: Chickasha list
David:
i will be in my regular spaces ( SL4 - SL6 ) in the south building with my babbitt bearing molds and linebore units and several rough hoods and distributor ignition units for model T and A/B Fords and some assorted T hand tools ... looking forward to the meet , i re-babbitted the main bearings in a 1917 block yesterday ...will use that block to display my linebore unit ... the block will also be for sale... always an optimist Gene French
Re: Chickasha list
I've seen a couple of posts about what people are bringing, but I still have to start loading up, so I don't have a list yet.
Chris Haynes
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Re: Chickasha list
I am bringing cash.
2nighthawks
- First Name: Harold
- Last Name: Schwendeman
Re: Chickasha list
I won't be able to attend this year, but I sincerely hope that this year's Chickasha pre-war swap meet is a huge success, because I have a feeling that the degree of "success" of this upcoming swap meet will have a lot to do with the continuation (or not) of Chickasha swap meets in the future!
Afrazer
- First Name: David
- Last Name: Frazer
Re: Chickasha list
Gene and Steve I look forward to see you guys at the meet as it has been awhile since I have seen you both. In fact I’m looking forward to everything at the swap meet, as I am chomping at the bit to go now as it has now been a long wait since the previous meet.
1925 closed cab TT
1926 two door sedan
1926 two door sedan
