Anyone have a lead for this window rubber?
ecory0
First Name: Eli
Last Name: Cory
Post by ecory0 » Sun Jun 27, 2021 5:03 pm
The rear side side windows on the 1924 Tudor are longer than the front windows and I only see the upper door window rubber for the fronts. Any leads on where I can get replacement rubber that is long enough?
Last Name: Strange
Re: Anyone have a lead for this window rubber?
Post by CudaMan » Sun Jun 27, 2021 5:05 pm
Check with the vendors, maybe they get it from the supplier on a roll and cut it to length. If they do have it on a roll, ask them to cut some to the length that you specify. :)
Post by speedytinc » Sun Jun 27, 2021 5:21 pm
If its just the rubber, a piece can be added for the extra length. It done for O rings in industrial applications. A touch of super glue.
ecory0
First Name: Eli
Last Name: Cory
Post by ecory0 » Sun Jun 27, 2021 5:24 pm
Thanks guys. I emailed Lang’s and they didn’t carry just the rubber. Only the bracket with rubber installed. I’ll have to see who they get it from.
Post by Mark Gregush » Sun Jun 27, 2021 6:14 pm
Go outside the box, Snyder's Model A section or do a search of automotive window weather seal.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Mon Jun 28, 2021 3:24 pm
Try Restoration Supply. I think they sell it by whe foot.
William L Vanderburg
1922 Center Door Sedan
