1:1 timber plans?
Myxr6turbo
Topic author - Posts: 89
- First Name: Shawn
- Last Name: Barnard
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
1:1 timber plans?
Afternoon everyone,
Are there any 1:1 timber plans for a 1926 T coupe that can be purchased?
Thanks in advance,
Thanks in advance,
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: 1:1 timber plans?
Not aware of any.
- First Name: Jeff
- Last Name: Humble
Not aware of any. I went to the Benson Ford Research Center in Dearborn Michigan and copied the factory drawings. Most of them were not 1:1, and some were very poor blueprints that didnt copy well. The research center has a printing service but they will be reduced in size and a bit pricy considering there are about 8 or 10 drawings of the individual parts and a drawing of the assembly.
- Last Name: van Ekeren
Shawn, is your T a USA import? as far as I know they are mostly steel, wood frame seat and a wood frame on the top. The top measurements for the top frame can be found with a google search of the MTFCA.
Shawn, an Australian built 26-7 coupe may be vastly different in construction to a US built car. Frank indicated that US cars have way more steel in their construction, compared with Australian built cars which still have a full timber base. If yours is a RHD Australian built car it would be advisable to find someone with a similar car and go from there.
Hope this helps.
Hope this helps.
Myxr6turbo
- First Name: Shawn
Thanks everyone,
This was an imported US car. I'll see if I can find the dimension in the search.
Thanks again,
Thanks again,
ChrisB
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
Myxr6turbo
- First Name: Shawn
Is this the link? Will this be the same as the 1926 Coupe soft top?
http://www.mtfca.com/discus/messages/41 ... 1395101672
