Name this tool
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
Board Member Since: 2009
Name this tool
Post by FordFool » Tue Jul 20, 2021 2:29 pm
Marked Ford 15 Z 4016. I can’t find it in the Big book. I’ll try to load a pic. I’ll have to figure out how to post a photo. It’s a puller for something. Any help?? Don
First Name: Henry
Last Name: Lee
Re: Name this tool
Post by Henry K. Lee » Tue Jul 20, 2021 2:43 pm
Very rare and hard to find I can tell from the photo's because it is invisible.
First Name: Dallas
Last Name: Landers
Re: Name this tool
Post by Dallas Landers » Tue Jul 20, 2021 3:03 pm
Im gonna name it Greg.
Re: Name this tool
Post by Mark Gregush » Tue Jul 20, 2021 4:54 pm
Not all "Z" tools are Model T. Model A, Fordson, and think Lincoln used "Z" tool numbers.
Re: Name this tool
Post by DanTreace » Tue Jul 20, 2021 5:19 pm
Crankshaft sprocket puller, later than T, found in listings on Ford tool collectors website.
Re: Name this tool
Post by TRDxB2 » Tue Jul 20, 2021 5:36 pm
You can add the pictures to your original entry by selecting the PENCIL ICON or by selecting POST REPLY at the bottom of the discussions
OR
THEN select the ATTACHMENTS tab to open acces to Files
Now select the ADD FILES button to get to your saved data.
once you have selected the file you want click on OPEN in the bottom right of that window and it will be added to the discussion -
continue the cycle of ADD FILES - select file - OPEN if you have more to do.
You can the PREVIEW your entries prior to SUBMIT button
There are ways to control the sequence of the added files. AND there are limits to size etc but that's lesson 2
John Heaman
Last Name: Heaman
Re: Name this tool
Post by John Heaman » Tue Jul 20, 2021 5:46 pm
I have the same tool somewhere. I haven't been able to locate it lately!
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Re: Name this tool
Post by John E. Guitar » Tue Jul 20, 2021 6:54 pm
John Heaman
Last Name: Heaman
Re: Name this tool
Post by John Heaman » Tue Jul 20, 2021 7:02 pm
It does say, 'not often seen!'
Re: Name this tool
Post by John kuehn » Tue Jul 20, 2021 7:42 pm
If this tool came out a little later after T’s were in production what did the Ford dealers use to remove the gear so they could replace it. Wondering if it should have been called crankshaft gear puller or am I missing something. Or?
FordFool
First Name: Don
Last Name: Kirtley
Re: Name this tool
Post by FordFool » Tue Jul 20, 2021 8:02 pm
Thanks Frank and John. A friend gave me some Ford Z tools last week I could find the others in the book but not this one. Thanks again. Don
