Which Way Does the Rear Axle Key Go ???
Post by RajoRacer » Sun Aug 01, 2021 12:28 pm
Over on the Ruckstell breakdown illustrations thread recently provided by Mr. Vowell, there seems to be a question regarding the proper or correct orientation of the rear axle key being installed onto the axle - I install with the taper pointing down and towards the bearing - there is an "artist's" rendition in the T Bible which appears to be the orientation shown & Jim Bartsch also follows. Does anyone else having definitive proof or documentation of the correct installation ?
Re: Which Way Does the Rear Axle Key Go ???
Post by Steve Jelf » Sun Aug 01, 2021 1:08 pm
I install with the taper pointing down and towards the bearing...
Me too. But after having to cut a notch in the outer end to pry one out when it was in the slot really tight, I grind a little chamfer on the bottom of the outside end so I can drive a screwdriver under it to get it out.
This didn't work.
A little pry bar made from a piece of key stock finally got it loose.
Post by RajoRacer » Sun Aug 01, 2021 1:44 pm
I've always grabbed the key with a dykes (side cutter) - works 95% of the time.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Sun Aug 01, 2021 2:38 pm
Some of the aftermarket keys are long. Be sure to check that it is not getting into your outer seal.
Post by speedytinc » Sun Aug 01, 2021 3:26 pm
The axle key slot tapers up @ the seal side. That ground radius in the key fits that. Later ford keys are shorter & dont have a ground radius in the key.
The short key works fine as is if it doesnt move inward.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Aug 01, 2021 3:53 pm
Just a trick to keep a well fitting but loose key from moving-1) upset a slight "ding" on one edge of the key to hold it in place in the axle. 2) a drop of super glue will hold the key in position also.
Post by Original Smith » Mon Aug 02, 2021 11:46 am
I lucked out many years ago, and obtained several NOS Ford script keys.
Post by DanTreace » Mon Aug 02, 2021 7:23 pm
Ford Service , paragraph 639.
Original Ford axle keys, the taper goes down and into the taper end of the axle keyway, toward the rear axle housing.
That way the entire length of the axle key surface is within the hub.
Square end of the axle key enters the hub keyway.
Axle key position.jpg (134.86 KiB) Viewed 2313 times
Don't forget to place a well greased new wheel hub felt, {B} into the groove of the inside of the rear hub, helps prevent axle lube leaks and acts as a nice bushing against the retainer cup over the ends of the Hyatt bearing.
Post by RajoRacer » Mon Aug 02, 2021 7:24 pm
Thank you Dan - that is quite definitive !
