Advice for 90 degree bend on solid brass half oval?
Topic author - Posts: 958
- First Name: Ignacio
- Last Name: Valdes
It is time to put the brass trim on the firewall. How to bend the pictured sold brass half oval at a 90 degree? I have read several places to do not heat it that it will break. I am thinking of just putting it into a vise and bending it, will that work? Is there a better way?
- First Name: Erik
- Last Name: Johnson
Re: Advice for 90 degree bend on solid brass half oval?
I think you would be better off cutting it and mitering the ends.
- First Name: William
- Last Name: May
Cut it, miter the ends, and silver solder it.
The joint will be undetectable if you do a good job fitting it.
A friend of mine is a jeweler, and I asked him to repair some cracks in some brass lamps. The first thing he did was run a jeweler's saw down each crack, through the crack and into the parent metal. Then he silver soldered the gap. When he was done, he polished it, and I couldn't even see where the repairs had been done.
So now I have a goal to shoot for.
Older post on ways of doing it cold, one-piece , with notching the underside for the 90 degree bends.
One used a mill, the other hand tools.
http://www.mtfca.com/discus/messages/17 ... 1320824601
- First Name: Rich
- Last Name: Bingham
Brass becomes brittle at low red heat. Some alloys work well cold, others need to be annealed to work cold, sometimes several times depending on what you're trying to do. Good info here on this particular problem ! Good luck, we learn by doing !
"Get a horse !"
- First Name: Erik
Notching the underside of flat brass stock and then bending it is not the same as notching half oval stock.
You can easily notch flat stock as the depth of the notch would be uniform across the piece.
However, with half oval, you would need to vary the depth of the notch and, even if you had the talent to vary the depth, I don't believe the corner would be nice and crisp after you bent the piece 90 degrees.
Frankly, I would cut the half oval stock, miter the ends, drill countersunk holes in the resulting trim and attach it with oval-head screws to the firewall. I wouldn't silver solder it. The joint should be snug enough without needing to solder it.
- First Name: Henry
- Last Name: Lee
Use a Cut off wheel from the back side carefully removing the area for a 90 degree bend, heat and cool about 4 to 5 times, bend to your liking. Polish to perfection! DONE!
The shallow U shaped capping is easy to bend by by filing a V in the legs of the U and pulling the strip around. This technique is fraught with difficulty with solid crescent shaped material. I'd be more inclined to radius the top corners of the wooden firewall so the moulding can be drawn around it.
- Last Name: Valdes
So I don't have a miter box but I do have a cut off wheel. I figured if I mess it up I would be able to salvage it and it WORKED! Looks really good too. Thanks for the tip. I did the flat screws on top and the round screws on the sides.
Henry K. Lee wrote: ↑Sat Sep 04, 2021 4:15 pmUse a Cut off wheel from the back side carefully removing the area for a 90 degree bend, heat and cool about 4 to 5 times, bend to your liking. Polish to perfection! DONE!
- First Name: Henry
- Last Name: Lee
Very Nice Job!
Looks great. Wondering if you used heat or just cold bent it with that dead blow mallet?
Super looking.
Super looking.
- First Name: Mike
- Last Name: Kossor
Nice work. Thanks for sharing your experience with this project.
- First Name: DAN
- Last Name: MCEACHERN
You don't want to bend brass while hot. Heating and cooling it will anneal it so that it can be bent cold without cracking.
The process of rolling the shape causes the brass to work harden, that's why you want to anneal it prior to bending. Heating it to a dull red and air cooling will anneal it. Best to heat it in a darkened area so you can easily see the color.
Just a guess, but suspect the new piece of brass half round stock was already in a soft annealed condition to start with. Most pieces like normally are soft, and bend some what easy.
- Last Name: Valdes
I heated it cooled it 3 times before bending with a MAPP gas torch. I never saw it turn red. I just got it 'real hot'. I notched it once, bent the two parts together until they kissed then notched again to get to 90 degrees.
