Can someone, anyone, give me an approximation of this cooling system capacity please.
Its a '25 block with a Waukesha Ricardo head and a 1915 Brassworks Radiator.
Thanks & Cheers,
Rob
Cooling system capacity
Rob Patterson
Topic author - Posts: 62
- First Name: Robert
- Last Name: Patterson
- * REQUIRED* Type and Year of Model Ts owned: '21 Canadian built Aust'n Bodied (Steenbohms) Touring & '15 Speedster
- Board Member Since: 2003
"When everything seems to be going against you, remember that the airplane takes off against the wind, not with it." HENRY FORD
Matt in California
- First Name: Matt
- Last Name: G
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Re: Cooling system capacity
Rob,
I am not sure what units you would like your answer in. But I would imagine that that system would have the capacity to cool one Model T engine.
Matthew
Matthew
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Hi Rob,
From the 1923 Ford Dealers’ Data Book:
Cooling system contains exactly 2 gallons 7-1/2 pints of water.
Radiator contains exactly 2 gallons of water.
Since you describe a combination of various parts, 3 gallons should be enough to fill your system from dry. I would hold back about a pint to see where the system settles after driving for a few miles and then add as needed to zero in on the proper operating level.
Keep crankin’
Eric
Keep crankin’
Eric
Rob Patterson
Thanks Eric,
I've now got it sorted.
Cheers,
Rob
Cheers,
Rob
