Differentials
Re: Differentials
Flip em over. One probably has the long thru bolts (left?). The other studs?
Re: Differentials
I prefer the security of the thru bolt style. If you use the stud type, the wire nuts together, no cotter pins.
- Last Name: Hjortnaes
Re: Differentials
The one on the left has grooves cut in the top and the spider gear appears to be out of alignment.
jeffstag
Topic author - Posts: 142
- First Name: Jeff
- Last Name: Versteeg
- * REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
Re: Differentials
I have several with those grooves. If we’re looking at the same thing those are supposed to be there. Here’s another one with the grooves
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
jeffstag
- First Name: Jeff
Re: Differentials
It looks like I can mix and match the different styles of differential halves. I can used the bottom half with the thru bolts, and then go with a top half with or without grooves. Both look good in terms of wear.
23 Touring
23 Fordor
25 TT
27 TT
23 Fordor
25 TT
27 TT
Re: Differentials
I have switched tops. The axle gear hole is/was originally 1.812" Measure them, to know for sure.
A best guess on the stud type usage is 14-20,21. The first gen after the 1.807" axle gears.
