I Almost Threw This Useless Screwdriver Away….
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Nov 10, 2021 7:49 pm
Last year. It came with a set of regular screwdrivers. Today when I installed the Bendix cover with my arthritic fingers it sure came in handy though I don’t know what it is called….😊
Re: I Almost Threw This Useless Screwdriver Away….
Post by TXGOAT2 » Wed Nov 10, 2021 7:51 pm
It's a Godsend when you need one.
Post by Steve Jelf » Wed Nov 10, 2021 8:44 pm
If you don't have that, you can do the same thing by putting a screw on the screwdriver with a piece of tape.
Last Name: Hatch
Post by Dan Hatch » Wed Nov 10, 2021 8:49 pm
In shop I started in years ago, we called them Monday Morning Screwdrivers.
Cap
First Name: Cap
Last Name: Weir
* REQUIRED* Type and Year of Model Ts owned: 24 & 25 C Cab
Post by Cap » Thu Nov 11, 2021 7:56 am
I prefer this type.. Gets into smaller spaces, and will screw hold upon extraction..
This is the one I use on the cover..
https://www.mcmaster.com/screw-holding- ... e~slotted/
Cap
Last Name: Seth
Post by perry kete » Thu Nov 11, 2021 7:57 am
I have used screwdrivers like that for years. I picked mine up at the electrical supply house and use it to hold the ground screw or other screws deep inside an outlet or light switch box. They work great when working overhead applying covers on junction boxes etc.
Last Name: Wrenn
Post by TWrenn » Thu Nov 11, 2021 8:01 am
I USED to have one. :lol: Sadly, I lost it. :roll: I need to get another one. they're super handy.
Post by Original Smith » Thu Nov 11, 2021 10:47 am
I got one from McMaster Carr.
George Mills
Last Name: Mills
Post by George Mills » Thu Nov 11, 2021 11:15 am
Like Tim, I use to have one. It was the two blade slide sleeve type with a really long shaft. Worked great. Somebody wanted it more than I did.
I now have one of the spring clip kind and they work well...just a bit tight for stubby fingers...
John Codman
Last Name: Codman
Post by John Codman » Thu Nov 11, 2021 11:35 am
Cap
I do too, but we have both.
Mikey1968
First Name: Michael
Last Name: Jewell
Post by Mikey1968 » Wed Nov 24, 2021 2:24 pm
You can also use a dab of EZ Turn fuel proof grease as it's pretty sticky stuff. I've started nuts that I could only get my finger tip on it by putting a dab on my finger tip and sticking the nut to it.
Last Name: Seth
Post by perry kete » Wed Nov 24, 2021 4:27 pm
The problem with using sticky grease is that as soon as I put it on my finger my nose becomes itchy and I always use the finger with the grease on to scratch it! :shock:
Post by Allan » Wed Nov 24, 2021 5:02 pm
I jam the head of the screw in a short bit of rubber fuel line, then use an ordinary electrician's screwdriver poked down the fuel line. Works a treat.
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Wed Nov 24, 2021 9:03 pm
The old trick was slipping a short piece of thin rubber tubing over the end of the screw driver to hold the screw.
Dan B
Last Name: Blaydon
Post by Dan B » Wed Nov 24, 2021 9:17 pm
Mikey1968
First Name: Michael
Last Name: Jewell
Post by Mikey1968 » Fri Nov 26, 2021 10:40 am
Itchy nose to grease issue! :lol: Been there! What's worse is when you get a dob of silver anti-seize on your fingers and don't realize it. You get silver all over the place and yourself!
