I have a brass Stewart speedo cable that measures 62 3/4" from end to end including the ends. I'm looking to get a cable kit from Langs for the inside and was curious to know if the 5ft cable is the way to go or do I need the 6 ft? Do you have to do anything with the inside cable to get it together (end pieces)? Does the 5 ft mean its just the cable length not including the end pieces? Anyone done this job that could offer some insight?
Mike
Stewart Speedometer Cable Help
- First Name: Keith
- Last Name: Townsend
Re: Stewart Speedometer Cable Help
Mike,
I believe it should be 48"
Keith
Keith
