Hi All
Is the Moore transmission drive shaft a cut down ford one or did it come with the gearbox from Moore ?
Picture for reference
Cheers
Andrew
Tracer
Topic author - Posts: 127
- First Name: Andrew
- Last Name: Webb
- * REQUIRED* Type and Year of Model Ts owned: 1915 Towncar 1921 Centerdoor 1913 Racer 1927 Fordor 1927 Tudor 1926 Tudor 1927 Coupe 1926 Ute1926 Tourer 1915 Town Car
- First Name: Keith
- Last Name: Townsend
Re: Moore transmission drive shaft
A cut down Ford driveshaft is used with a Moore transmission.
Andrew, mine was a whole unit when found, with the shaft already made to fit, so i can't answer your question. Do you have the change lever/ It comes with a quadrant which allows the lever to be set in neutral, allowing the Moore equiped car to be flat towed. If you have a Moore, it pays to learn to change, both up and down, while still on an up slope. You learn to drive defensively to be safe. If you go to a 3:1 diff ratio, let me know and I will run you through how to fit it all together.
