temperature probe in sherman head???
Loftbed
First Name: Rod
Last Name: Letcher
* REQUIRED* Type and Year of Model Ts owned: 1915 Speedster
Post by Loftbed » Fri Mar 11, 2022 1:42 pm
Am I wrong in assuming that this port is for a Temp Probe? (black arrow)
Rod
:D
1965 Shelby Cobra (Factory Five repo)
1957 Ford Thunderbird
1941 Ford PU
John iaccino
Last Name: Iaccino
Re: temperature probe in sherman head???
Post by John iaccino » Fri Mar 11, 2022 2:39 pm
I have a Sherman head on one of my Fords. I was told it was a port for removing sand from the mold. I don't know much about this process, but that is what I was told.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Mar 11, 2022 3:23 pm
yes you can install a temp gauge sensor in that hole. Some heads have them and some don't.
Loftbed
First Name: Rod
Last Name: Letcher
Post by Loftbed » Sat Mar 12, 2022 12:27 pm
Thanks Dan.
:D
1941 Ford PU
Loftbed
First Name: Rod
Last Name: Letcher
Post by Loftbed » Thu Mar 17, 2022 4:52 pm
I had a brand new Bosch mechanical temp gauge still in the packaging (who knows how long I've had that laying around). Installed it in the head and am running a 190* temp consistently after about a 15 minute drive, seems about right to me.
Just saying
Rod
:D
1941 Ford PU
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Thu Mar 17, 2022 11:46 pm
Back in the 1920’s many flat head T racers ran a extra water pipe out of that location in the head in order to improve cooling circulation at the back cylinders. The extra pipe would tie into a modified outlet at the front of the head. If you want a to use a mechanical gauge you can tap the T block rear core plug hole as another option.
kmatt2
First Name: Kevin
The temp probe out of that location in top of the head, as shown, is just fine also.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Mar 18, 2022 8:56 am
When pouring a casting you have to hold the core some how from moving when being poured, some use the core others use chablits that melt into the pour. Years ago when I made some cast iron heads, I held the core from the side and so there was a soft plug in the side of the head.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Sat Mar 19, 2022 10:09 pm
Not a bad idea to put a zinc in.
