Steering Gear Ball Arm
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Post by SurveyKing » Mon Apr 11, 2022 7:06 pm
I have a pitman arm ball that measures .965 by .992 is that too out of round to be used successfully? if so, what are the recommendations, go with a repro? Thanks
Re: Steering Gear Ball Arm
Post by speedytinc » Tue Apr 12, 2022 8:28 am
Thats enough wear to fix or replace. If not you will have a loose situation straight &/or binding in a turn. The repops seem ok. They are cheap enough. I have installed a few & have not heard of any failures. I personally prefer to weld them back up & ground the ball round. The ball should be 1.000". One can compensate for some drag link wear making the ball a bit oversize.
Post by Original Smith » Tue Apr 12, 2022 10:01 am
Bill Barth used to sell reconditioned pitman arms with new balls on the end. Don't know if he still does. He used to sell them at Chickasha.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Tue Apr 12, 2022 10:39 am
You dont say what year your car is. The reproductions are of the last design steering gear ball arm. Darryl
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Tue Apr 12, 2022 12:12 pm
It is a 1925 RPU. Parts listings show part number 3547 for that year.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Sun Apr 17, 2022 3:31 am
I built mine up with bronze and ground to a close fit with a hand grinder and finished with emery cloth using a good cap for fit. Worked great and didn't take very long either. JMHO Dave
1925 mostly original coupe.
Post by Allan » Mon Apr 18, 2022 5:44 am
Easiest fix for a 25 model is a new repop. Early slim ones are well worth fixing.
SurveyKing
First Name: Daniel
Last Name: Snell
Post by SurveyKing » Tue Apr 19, 2022 10:42 pm
Anyone have a contact for Bill Barth whom Larry Smith indicated used to rebuild the pitman arm ball? Thsnks
Post by TRDxB2 » Wed Apr 20, 2022 12:20 am
All I could find of the gentleman .
Post by Allan » Wed Apr 20, 2022 6:53 am
I save early slim ones in the following way.
Set some calipers to 1/2" and grind two flats on opposite sides of the worn ball, using the calipers as your guide.
Do the same on adjacent side to make a 1/2" square.
Then knock the four corners off and hand file the rest into 1/2" round.
I use a 1/2" die to tap a fine thread onto the created stub.
Chuck a new straight shank replacement tie rod ball from the vendors in a lathe, counterbore the ball and tap a 1/2" fine thread into the hole.
Use the straight stub and some lock-on pliers to thread the new ball onto the pitman arm, with loctite if desired.
Cut off the stub and make a good weld to lock the ball to the arm. File to finish.
The neck on the arm is still smaller than the stub created for the new threaded on ball, so there is no weakening of the arm. The weld does not create enough heat to worry the metalurgy/strength either. And, if you ever have to replace the ball again, it is not hard to do.
Hope this helps,
pron022020
First Name: Tyler
Last Name: Prondzinski
Post by pron022020 » Wed Apr 20, 2022 8:20 am
I personally wouldn't cut the old ball off and weld a new one on. If that were to fail then you have no steering and are most likely dead. I'd rather spend the time welding and filing the ball.
Post by Jerry VanOoteghem » Wed Apr 20, 2022 12:33 pm
Sent you an email with contact info.
Post by Jerry VanOoteghem » Wed Apr 20, 2022 12:34 pm
That's Bill's picture, but I'm pretty certain he's not the piano tuning Bill...
Post by TRDxB2 » Wed Apr 20, 2022 3:52 pm
There is also a Bill Barth Jr in the same Town, Berthoud CO, so they must know one another (pop 10,000+) contacting one could get to the other.
Post by Jerry VanOoteghem » Wed Apr 20, 2022 3:55 pm
Yes, I'm sure they all get together on weekends. :lol:
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed Apr 20, 2022 5:05 pm
Sounds fearsome lot of filing and grinding - but I have done it too, just takes patience and time. (not bad for an accountant either ;-) )
