Period Split Wishbone Setup
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Tue May 10, 2022 2:59 pm
Looking for photos or information on Model T split wishbone setups from the 1920s or 1930s. I am particularly interested in how the wishbone rod mounted to the frame. I don't really want to use a modern ball joint style mount as it won't look correct.
Re: Period Split Wishbone Setup
Post by TRDxB2 » Tue May 10, 2022 3:32 pm
Here are a few
Post by TRDxB2 » Tue May 10, 2022 3:36 pm
Two more (I have both - haven't decided which I am to use)
Hank's
HANK s.jpg (83.5 KiB) Viewed 3069 times
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue May 10, 2022 6:34 pm
Using Model A Tie Rod ends is another method. Not 100% era correct, but much better than using heim joints or modern tie rod ends.
Post by TRDxB2 » Tue May 10, 2022 9:40 pm
Model A designs
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Wed May 11, 2022 7:59 am
These are Ford 8N parts. Might be helpful if your'e scratch building your radius rods and they do have the "vintage look". Readily available on Ebay. Enjoy
Last Name: Wrenn
Post by TWrenn » Wed May 11, 2022 10:20 am
Since your cars already have the tried and true under-axle wishbone I'm only curious as to why you want such a
set up? Man that is one wicked looking contraption for sure! I reckon it would be great, if not necessary, should your
roads be filled with lots of potholes and rough as a washboard.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Wed May 11, 2022 2:30 pm
Tim- my lowered front end set up requires splitting the wishbone.
Last Name: Wrenn
Post by TWrenn » Wed May 11, 2022 4:24 pm
Ah haaa....makes sense. Thanks.
The other Tim
