Member information block at the right
Last Name: Seth
Post by perry kete » Sun Jan 06, 2019 12:01 pm
How do you post a picture of your car in the member information block at the right side of the post?
Last Name: Strange
Re: Member information block at the right
Post by CudaMan » Sun Jan 06, 2019 12:04 pm
Click on your username in the upper right. Select "user control panel". One of the options will be to add an Avatar. Be aware that the picture you select to be your Avatar must be shrunk down to no more than 90 pixels high and wide.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sun Jan 06, 2019 12:08 pm
1924 Touring
Last Name: Seth
Post by perry kete » Sun Jan 06, 2019 12:13 pm
Being that I am totally computer ignorant what is "Avatar" and do I have to download a special program to use it?
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sun Jan 06, 2019 12:14 pm
It's the little photo like I have at the right of the screen.
1924 Touring
Post by Mark Gregush » Sun Jan 06, 2019 12:14 pm
Maximum dimensions; width: 90 pixels, height: 90 pixels, file size: 21.00 KiB.
I tried it but by time I got it down to 90X90 it was still 36+ KB and no longer in focus. I was going to wait till the dust settles and send a note to Chris to see it it could be changed.
Click on you name, when the window opens you will see edit profile after your name, click that. In the new window that opens the profile tab will be open, edit avatar is in the drop down on the left, click on it.
Last Name: Seth
Post by perry kete » Sun Jan 06, 2019 12:27 pm
Thanks everyone I got it!
WOW! it even added my photo to all the old posts where I was asking how to add it!
Post by Steve Jelf » Sun Jan 06, 2019 12:52 pm
Mark, I think you need to start with a full size photo. I picked one 3468 pixels wide where the car filled a lot of the picture. I made a copy and cropped it to cut out most of the stuff on either side of the car. That left me with a picture 1560 pixels wide, which I resized to 90. That tiny size can't show any detail no matter what you do, but I think starting with the biggest original file you can find will get it as good as it's going to get. I started with this.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sun Jan 06, 2019 1:44 pm
You nailed it Steve.
Starting with the highest resolution photo possible is the key to a clear Avatar photo.
1924 Touring
John Warren
Last Name: Warren
Post by John Warren » Sun Jan 06, 2019 5:32 pm
I started with an iphone photo, put it into paint, stretch skew to 20% , saved that then did it again to 90%. Sure is small :lol:
Last Name: Juhl
Post by Oldav8tor » Sun Jan 06, 2019 7:40 pm
When resizing a photo to 90 pixels, reduce the largest dimension to 90 and let the other fall where it may.... Usually there is a command like "constrain proportions." If you don't do so, your photo may end up out of proportion.
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Mon Jan 07, 2019 11:11 pm
The birthday year starts at 1919...
I hope we aren't slighting anyone over 100 ! :?
